dnmccoy's avatar
dnmccoy
Question about my F150's specs
Excuse my ignorance, but I got the go ahead from my better half to start researching a camper for us! I have a 2007 F150 and got the specs from the link below:
http://www.fordf150.net/2007/2007-ford-f150-specifications.php
It says my max GCWR is 14,000lbs and that my max loaded trailer weight is 8600lbs. I saw something in my owners manual that's said if you do not have the towing package that the max loaded trailer weight is 5000lbs. Which is right?
Thanks!
  • They're all right. None of the information you gave contradicts anything else. Do you have the towing package or not? Sounds like 5,000 if you don't, 8,600 if you do. I would have to assume that your truck weighs about 14,000 - 8,600 = 5,400 empty. Of course, any weight added to the truck must be subtracted from the tow weight. So, that 8,600 number will come down some as you add passengers and gear to your truck.
  • I would look at the VIN plate on the driver's door jam for the vehicle info.
    The owner's manual is generic and won't give exact specs for your vehicle.
    More info here
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
