wa8yxm
7 years agoExplorer III
The only thing I would be concerned about is this.
THe A/C also removes water from the RV this "Condensate" as it is called drips onto the roof. IF the Roof over the RV has clearance at the sides of the RV so the water can continue to the ground.. Just run the exhaust fan to keep a good supply of fresh air in the "Attic".
If the Attic roof is Sealed to the RV roof. YOu need to provide a way for the water to go to ground.
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: 3 hours ago
