phattwoohie's avatar
phattwoohie
Question From a Really Big Guy Maybe You Can Answer
First, let me say hello and thank you for deciding to read my question.
I am 40 years old and have never owned an RV or Motorhome but my wife and I want to purchase one in the next 12 months. I have a few reservations because of my size however. My wife is normal but I'm 449 pounds. I know I can find an RV with a larger bathroom, I've looked at some photos of some used ones with bigger walk in showers and toilets that were not squeezed in a corner.
My real concern is if I purchase a 5th wheel model and the fold out steps. I have never actually walked into an RV before but I'm worried about the fold out steps weight capacity and their ability to hold me as I walk up them. I was too embarrassed to call and talk to someone at a dealership, but I felt like online here I could be a bit more anonymous.
Do they make a heavy duty set of steps or how sturdy are the normal ones that come on an RV? I recently found out they make Handicapped model RV's with larger entrance doors and even wheelchair lifts. I have considered one of these models as they have a wider walkway throughout and usually bigger bathrooms standard. I don't want to have to go that route unless I have to though.
Any info is appreciated.
  • This is an RV step stabilizer that is rated for 750 pounds.
    Alot of dealers use two under each bottom step (one at each end) on the coaches they bring to RV shows.
  • lanerd wrote:
    I'm a little guy of 220 and cringed every time I stepped out my motor home as the steps would move downward and creek and groan. I solved my problem by getting a small scissor jack and placing it under the bottom step. The jack (being adjustable) can be raised or lowered due to the steps being at different heights when at different campgrounds/parks. Sometimes getting the coach level requires the steps to be further or closer to the ground.
    Hope this helps
    Ron
    Seems like the easiest & best approach to me.
    On another note, My steps on my TT have a custom bracket made by the factory & are welded to the frame.
  • If you get a motor-home, you'll have to get DW to be first one out and last one in, so she can put the extra support under the steps before you use them and remove it before you pull out. TT or 5er, that's not a problem.
  • Hi there - I'm a fellow big guy, 6ft 6 and heavy. I've made a few "improvements" to my rv to help it last longer.
    for the entrance, consider something like this:
    Aluminum Step Stool
    The step is great - it's a large target, which works great for my size 17 feet ... the factory steps were so narrow, easy to miss sometimes.
    I also bolstered the insides of the dinette seats with 2x4s and steel corner bracing - the oem used 3/4" x 3/4" strips, stapled together!
    My rig has a queen size bed built on a platform, that doubles as the outside basement and indoor water storage compartment. I braced parts of it with 2x4 and steel as well.
    The toilet is no problem, other than having to basically fold in half to use it (why so low to the ground!).
    The shower, forget it. My ceiling is about 6'8 inside, when I have my boots on I walk around hunched over. The shower is built up on a platform another 3 inches higher (so the drain lines fits under it I guess). If I really have to use it, I can fit in there, but most of the time I just wash up in the sink and rinse my hair in the shower. One of these years I'll put some quick connects on my outdoor low point drain lines, so I can connect a mixer valve and have an outdoor shower.
    If I win the lotto, I'll get a 5th wheel with 8 to 9 foot ceilings, other than that I really enjoy my little trailer.
  • I'm a little guy of 220 and cringed every time I stepped out my motor home as the steps would move downward and creek and groan. I solved my problem by getting a small scissor jack and placing it under the bottom step. The jack (being adjustable) can be raised or lowered due to the steps being at different heights when at different campgrounds/parks. Sometimes getting the coach level requires the steps to be further or closer to the ground.
    Hope this helps
    Ron
  • I'm 6'2" and weighed about 260 and my steps broke. I started putting a block of wood under it when I used it. They're definitely not made for big guys. Also, the ladders on RVs aren't rated for big guys, either. Mine are rated for 220 lbs max.
  • I'm a big guy too (about 400 lbs.) and I have not had any trouble with the steps on my hybrid or the TT in my signature. I couldn't use the bathroom in the hybrid so that was one requirement when we moved up to the TT. I have no problem getting in/out of the TT with the steps (no modifications), the shower and using the toilet. We plan to use the TT for snowbirding a couple of years from now. BTW, welcome to the forum. Also, we chose a TT over a 5er to avoid the extra steps on the inside.
  • Welcome to the forum. I went to our local state park this past week and the camp host setup had a fifth wheel. He had setup a set of wooden steps to get into his unit instead of using the flimsy metal steps that most rv's have. i suspect with you having a big truck required to haul a fifth wheel you could come up with a similar plan.
    And I'm not trying to be humorous, just throwing it out there, but some fifth wheels have a garage for play toys such as motor cycles, golf carts, etc. these are typically called toy haulers. The key though is they have a ramp out the back.
    Good luck.
  • well welcome, you ain,t the only big guy out there, but to answer your question, I,d put a support under the step, on my friends, we had a aluminum square I had welded up ,slides under the step, and don,t be shy, you got questions ask, we,ll all learn some thing.
