pylotguy1's avatar
pylotguy1
Question on use of electric coffee maker in RV
Taking my first RV trip in a Class C. Sorting out electrical use items and wanted to see what people recommend for making coffee. I have a small, 5 cup Mr. Coffee but cant seem to find how many amps it pulls. It should be about a 650 watt machine. Any suggestions on whether it would be suitable to use? Thanks for your help
  • Thanks for your note. So assuming other electricals aren't in use, I should be able to plug it in on the inside as well?
  • You'll be fine with your coffee machine. If you have any doubts, the MOST that will happen is, if you pull too much power and exceed your camper's 30 amp or 50 amp limit, the main breaker in the camper OR the breaker at the campground electric pedestal will pop. If that happens, simply turn something off (like your air conditioner or electric hair dryer or microwave), reset the popped breaker and make your coffee. No damage, using more power than you have available will just result in a popped breaker. If this happens, you'll figure out real fast what electric components can be used at the same time and which ones draw too much to be used with others. Bring it along and enjoy your coffee. (tip: If you air conditioner is turned off when you make coffee, chances are, you'll have ample power for your coffee machine.)
  • I have a similar coffee maker. No issues. I make my coffee outside as my DW doesn't like the smell of coffee, so I am plugged into the outside outlet. She can run the microwave (on it's own breaker) at the same time. 650 watts is about 5-1/2 amps draw.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 29, 2025
