gbopp
Dec 16, 2017Explorer
Do you have the can of Great Stuff that is designed for a dispensing gun?
As mentioned above, the regular cans have a trigger.
I have found that if you leave the dispensing tube screwed into the can, you can leave it dry and later clean the tube. Then you can use the remaining foam for other projects. I have used leftover foam several weeks after the initial use. YMMV
WEAR DISPOSABLE GLOVES when working with the foam. It's very difficult to remove from your skin unless removed quickly after contact.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 04, 2026
