NanciL's avatar
NanciL
Explorer II
Dec 16, 2017
Question on using "Great Stuff" foam sealant
Has anyone here used Great Stuff foam sealant?
I have an open space under my shower where I can look down and see the ground and I am going to use it to seal it.
I have read all the directions on the can, but I can't figure out how to stop the flow once it is started, and it doesn't say how.
Once the straw is screwed into the tube the foam is supposed to start flowing, but how do you stop it?
Jack L
  • I've used that in various places, home and RV, to closed holes. In the RV, I used it to seal the hole where the water plumbing comes through the floor. Put some newspaper down on basement carpet else you'll never the the stuff out of the carpet. It does tend to go everywhere.
    Like you I had a gap in the sheet metal under the shower. The problem was the the shower is over the wheel well and the road grime and water made a nice mess. I screwed down the sheet metal and then used great stuff to fill in the gap on top.
    You can get a can with a trigger type applicator tube which does stop, but to be honest if you don't use the whole can, just throw it out. You'll never be able to clean the stuff out of the tube so you can use it again.
