ekirkland's avatar
ekirkland
Question on wheel psi rating
I'm looking to increase the weight capacity of my tires which are currently Rainier ST205/75R14C with a capacity of 1760 lbs. The wheels are rated at 2200 lbs. @ 60psi; Sendel T09-C2 / J1204 wheels. I'm looking at Kumho 857 tires which are load range D with a capacity of 2271 lbs @65 psi. Would you run 65 psi on these wheels or stay at 60psi max to comply with the wheel rating? I realize that I would sacrifice some weight capacity running at a lower psi; how much? The travel trailer is the one in my signature below.
