QCMan
Apr 22, 2021Nomad III
Try downloading the install sheets from Reese. They are exacting on what should be where. Do not trust that the dealer did it right! My first trailer with that hitch, which has the dual cams, the dealer was way off on the install and both sides were not even close. Start from scratch and do it with a ready to camp trailer. The fine tuning is tedious but when it is right it will make you very happy while you are towing. I am now using the same hitch that I bought in 2004 on my third trailer. Other than changing bars for each trailer to accommodate different tongue weights it is original and has over 50,000 miles on it.
You will find that there will be two chain spots to hitch up with. In my case, four free links with nothing in Black tank and five free if the tank has more than half. When you get into a routine of packing the same things in the same place it makes it easy. At that point tanks will be the only variable. Be patient setting it up and you will be rewarded.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
