blt2ski
Feb 27, 2020Moderator
Not that hard to remove that little battery. Put in as mentioned a size 24, or a smaller U2? Mower battery on hitch. Or as I did with my enclosed trailer. Put the U2 in back corner. Not best from a eight standpoint. But at 20 lbs, not as bad as a 24 or larger battery.
Another issue with said installed battery, besides probably not set up for lights. Many trailers like this are sent with a single use battery. In other words, if it gets used in a true break away, or if your being an AH to an LEO and they decide to pull cord and do a check that the battery locks breaks. Then decide to do an equal test later. That 2nd test will fail, you have a failed brake system, a fine, and can't pull the trailer until e brakes work again. ....
Any way, better to out a deep cycle bigger battery on trailer if using the lights not hooked to TV if it's wired that way.
Marty
Marty
Looking for advice before your next adventure? Look no further.25,200 PostsLatest Activity: Jul 01, 2026
