rjf7g
Jun 04, 2013Explorer
You want a good selection of beers? Reasonably close to grounds is http://www.beerrun.com/ - then, there is http://www.stmaartencafe.com/ - it's walking distance to the Rotunda. You will be at "The Corner" if you head to St. Maarten and there are a ton of choices there. If you are coming through Nelson County on rt 151, you should check out http://brewridgetrail.com/.
I am a 2x UVA grad and work in Cville...so, this was an easy question for me!
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
