Grit_dog's avatar
Grit_dog
Trailblazer
Jul 27, 2019
Quick hitch receiver slop fix
Just towed the boat behind the camper which requires a hitch extension.
The slop from receiver to extension and extension to hitch results in the hitch dropping a couple inches and banging over bumps.
I tried a quick fix, shoved a fender washer under the shank in both connections.
Worked great and the washers didn't fall out after almost 1000miles of towing.
Sharing a free fix
  • ^That would guarantee the shim stayed in.
    Little noise doesn’t bother me cause I’m used to towing pintle hitches, but yes that’s a great suggestion.
  • Fun.
    Wonder if you couple that with a u-bolt fix if it would keep it from sagging and keep quite. I just have the u-bolt and love it, but it still sags, so maybe Ill try a shim.
    Also, check that your hitch is tighter on the ball. Put a loose ball in the trailer hitch, close and see how much play there is. Tighten the nut underneath to where it is snug, but not binding.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
