- traveylinExplorerHad a remco for 3 years applied to a vehicle I already owned. It worked had issues.
I would not buy a new/used vehicle to install a remco on. Their are two many other tow compatible vehicles that do not need it.
pops - moishehExplorerWe had one for 5 years. Every 6 months I would clean it and spray with silicone lube. Worked great. You do not need a spare shaft!
Moisheh - camper19709ExplorerI have used the Remco disconnect for 10 years on my 04 Chevy Astro van with no problems. Wouldn't hesitate to buy one again.
- Corkey05ExplorerI used a Remco disconnect for 8 years on my 95 Blazer until last year when I traded it. Not one time did it let me down, worked perfect for all those years.
I know several that use them and haven't heard a single complaint. - Phil___StephieExplorerI used the Remco disconnect on a two wheel drive GMC pickup, worked fine. My brother and I installed it, so it was done right. If needed, wouldn't hesitate to do it again.
- TrackrigExplorer IIA friend used one. He always had to carry a spare drive shaft and had many problems. Bought a different toad after a year or two so that he didn't have to put up with it anymore. Don't waste your time and money.
Bill - BumpyroadExplorerif you mean drive shaft disconnects, I used one, hated it. got to crawl under toad to clean/grease it. mine kept popping out of sync. try one before you buy one, after jamming a rotating gear into a stationary one and hearing it grind, not a fun thing to do.
bumpy - j-dExplorer IIThey work but many who've had them hate them. They're an expensive part, and the only way I'd have one would be to also have a backup plain driveshaft.
Some of the problems are installation - The cabling has to move freely. Some are environment - Gravel and sand will goof them up. Others have complained about durability.
Search "Driveshaft Disconnect" and you'll find lots of comments.
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Nov 19, 2025
