craig7h
Nov 30, 2020Nomad II
I do not dry camp so really can not give much help on alternative heat source. I would however stay away from any type of propane radiant heat, such as the Buddy Heater. Your unit is to air tight to use that indoors.
I would hope that after time you will get used to the on board furnace. Just remember also that it uses a lot of propane so have a good supply handy.
Depending where you camp a generator may be an answer but then at night that noise could be worse.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
