ktmrfs
Nov 30, 2020Explorer III
we dry camp a lot, our solution is use a heavy quilt, set the thermostat at 50F at night, then either get up in the AM and turn it on, or use a setback thermostat to warm the trailer before you get up. The noise alone is enough to interupt our sleep. And it hard to find a furnace that is low power draw.
On the Mr. buddy etc. Any indoor propane heat source is going to dump about 1 gallon of water in the air for every gallon of propane burned, Mr Buddy, stove, oven etc. WH and furnace vent outside. Now in a dry climate that water may be fine and even desireable. In areas with high RH to start with, it can result in condensation problems.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
