Sjm9911
Nov 30, 2020Explorer
Never run a portable propane heater inside without make up air. Thats why you had headaches from the Mr. Buddy. Always have a co detecter also. How long are your trips, what temps and what is your battery set up like? Unfortunately, you dont have a ton of options. Portable propane, or the on board heater. The on board will burn through the voltage before the propane. You may get used to the sound in time and can recharge the batteries through solar or a generator. Otherwise you are back to the portables. Some have installed diesel heaters, but that sounds like work and you have to carry another fuel.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
