wingrider6's avatar
wingrider6
Quiet Water Pumps
Bought a 2014 Springdale with a Flojet water pump. This pump is the loudest pump I've ever had. I'm going to replace it with something that is quiet.
Years ago I purchased a Shurflo Whisper King that was very quiet but don't see them listed anymore.
Anyone have any suggestions on what pump to buy? All say "real quiet" in their info, as well as the Flojet I now have, but since this pump works but is noisy I would like to make sure I get what I'm looking for--quiet!
The pump is only inches from wife's head when in bed.
  • MitchF150 wrote:
    It's not the water pump that's loud... It's how it's mounted and/or the pipes that are making all the noise...
    Ever heard a Flojet Mitch?
  • It's not the water pump that's loud... It's how it's mounted and/or the pipes that are making all the noise... ;)
    It probably has little rubber mounted feet on it, but if it's screwed down too tight and compressing those rubber feet, it's not doing any good.
    If the outlet pipe from it is mounted directly to the floor, then that will cause the pipe to rattle and that's what you are hearing..
    Try running the pump "dry" for a few seconds.. (no, it will not damage the pump)... Notice how quiet it is... It's not until it's pumping water and banging on the mounts and the pipes that is causing all the noise.
    What I did was make sure the mount was not too tight. Then, I put some foam insulating material on the pipe coming from the pump. Finally, I added about 2' of hose to make a "loop" between the pump and the pipe to help keep the vibration out of the pipe and that has made for a very quiet pump..
    Almost too quiet.... A couple of times, I didn't get all the air out of the system and had the pump on and it just ran and ran for who knows how long before I caught it and opened up a faucet.... Oh, it's still the original pump from 2002, so running it 'dry' does not really kill it on the spot.. :)
    Anyway, lots of other posts on this too..
    Good luck!
    Mitch
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
