BBdawg's avatar
BBdawg
Radio/TV gone bad, Replacement?
I have a bad audio/tv system with built in surround sound that apparently got hit by lightening. (my best guess)
The system is(was) a very nice Panasonic combo (2005) model. Tube tv and very heavy am/fm/cd/dvd main unit with 4 ceiling speakers, a large center speaker and a large woofer.
I replaced the Tv with a new LED, all is good except the sound is terrible.
The main unit will tune in radio stations but only two of the speakers will work. I checked all of the speakers on the working output terminals and all speakers are good.
I would like to keep my current speakers, as they are nicely wired and seem to be very good quality.
What options do I have? We are not audiophiles and expensive sound is not needed. Just a plain system to play the am/fm/cd/tv and reasonable sound from the existing 6 speakers.
The original system was all 120volt.
Ideas guys?
Thanks
Randy
  • westend wrote:
    So you wish to replace your 120V surround sound receiver, if I'm understanding you correctly?
    There are a lot of good choices out there. I have a Panasonic XA-58 at home. It is no longer made but is a really good receiver, 95 watts/6 channels, measured, through a splendid Class D amp.
    In the TT, I use an older NAD stereo receiver with two pairs of speakers. The NAD has no lower LFE channel and doesn't decode 5.1, 7.1 or other. I don't feel I'm missing much.
    I would suggest to look for an inexpensive surround sound receiver at one of your local electronic outlets. It will have the connectivity you need and doesn't have to have all the bells and whistles as a typical, higher end residential unit. Yamaha and Pioneer are two names I trust.
    Ok, a "surround sound receiver" is what I need. I did some initial searching and found only complete systems with new speakers and all.
    this time I used the correct search term and found exactly what I was thinking of.
    HOWEVER, the cost of a new unit has me rethinking repair vs replacement. On further research, I find that my current unit is not as great as I thought. It actually came out in 2002 and was quite cheap back then. It does have the cd/dvd player built in but reviews show very poor quality and guess what? A serious speaker output problem with the system overheating and blowing the output circuits.
    Well guys, I guess I will dump it all and go with a current model "movie theater in a box" and just "Be Happy"!
    Thanks for the input and advice. Once again, the folks on RV.net come to the rescue of those of us who are novices!
    I consider this topic closed.
    Thanks to all and have a Great Labor Day!
    Randy
  • Mandalay Parr wrote:
    Can you play a DVD and get sound out of all speakers?
    Good question. I don't know as I have not connected the unit to the new tv and will have to go get a dvd to test it.
    I'll let You know back!
  • edbehnke wrote:
    tv sound is getting worse on tvs...a lot of them have speakers in the rear.
    get some external speakers, that will work well.
    http://www.cnet.com/news/a-cheap-and-easy-fix-for-crummy-hdtv-speakers/
    I would like to use the existing speakers as they are already in place and they sound real good.
  • rockhillmanor wrote:
    Is this in your RV or house?
    If you don't get any good answers here all I would add is there is a GREAT TV repair in Wildwood, FL.
    I took a couple of my first cheap flat screens that either lost their sound or coax connection to him when everyone else said to just throw them out and buy new ones because no one would fix them.
    He fixed both of them and for a real low price. He does a lot of work for the all the snowbirds TV's. I highly recommend him.
    This is in the RV. Thanks for the info on the repair. That might be a good option but a hundred mile round trip so will have to see what other options might pop up.
    Thanks Again.
    Randy
  • So you wish to replace your 120V surround sound receiver, if I'm understanding you correctly?
  • tv sound is getting worse on tvs...a lot of them have speakers in the rear.
  • Is this in your RV or house?
