Re: AC duct leaking
Most likely the ducts were not sealed properly at the A/C unit and/or the various registers. To check the unit connections you need to drop the ceiling assy. of the unit. To check the registers; generally the louvered portion pops out. Any gaps in the connections can be sealed with metallic duct tape available at HVAC or plumbing supply houses.
No RepliesBe the first to reply
