seaeagle2
Aug 19, 2019Explorer
The torque values should be in the installation manual. Those flare fittings are the weak point at this time. There is a whole industry trying to produce an easy to use, reliable tool that will consistently produce a non leaking flare. If it was leaking, and you just tightened it down, it's probably going to leak again at some point.....
Looking for advice before your next adventure? Look no further.25,107 PostsLatest Activity: Jan 29, 2025
