Re: Installing Propride 3P hitch - final adjustments?
I found that mine was quite easy. After it was set up so that the trailer was level, I tightened the bars so that 1/2 the front end lift came back down (per Ford manual). I actually marked that spot on the spring bar jacks with a yellow paint pen. Now every time I hook up, that's where I crank it to.
If i find the ride a bit too bouncy, I'll lower the jacks a bit to put more weight on the tongue, but generally speaking the setup is not finicky at all.
Good luck!
Pete
No RepliesBe the first to reply
