ve7prt
Mar 03, 2020Explorer
JaxDad wrote:
The law, which is pretty uniform across all of North America, says you must have a minimum of 2, and a maximum of 4 LIT lamps on the front of a motor vehicle. That is why on 4 lamp systems with fogs, the fogs won't come if the vehicle's high beams are on, or the high beams turn the fogs off.
I've not seen anything that restricted how many lights you could have, just that you can't light up more than 4 of them at a time.
Then PLEASE tell some of the car manufacturers that! I'm starting to see more and more cars/SUVs/crossovers with 6 lit white lights: headlights, fog lights, AND extremely bright LED strip lights. And they look like a ball of light coming at you until you're less than 50' away from them! Or the Ford trucks that have 4 very bright headlamps on (all separate bulbs too), AND their fog lamps (2 separate bulbs there).
Regards,
Mike
