lrak
May 04, 2013Explorer
JConatser wrote:
Mainly note, however, that your current Total weight of 8700+ is already greater than the maximum Toyota calls for (8100); once you add your 1000 lb. motorcycle, plus probably another 300 - 800 lbs of "stuff", you're gonna be 2000 lbs or so over their maximum limit.
Bottom line, (assuming the Toyota numbers I found are correct) you need a bigger truck.
FWIW, GCWR with tow package is 11,100. 8,700 is less than 11,100.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
