ScottG wrote:
starzen wrote:
was connected for quite a while.
strange thing is as soon as i plug it directly into the battery it works fine but when it is plugged into the wire inside the TT it stops after a few blinks.
i even hooked up a 12V pump to the same wires and it runs fine
This is a stretch but is there a flourescent or LED light on that circuit?
I wonder if there's some kind of noise present.
dont think so but today i will see if i can do some more testing
another thing i thought was to test if the ground is clean. I had him test the voltage and it showed 12.4V but maybe the ground has some issue
