dolfinwriter
Oct 29, 2020Explorer
I decided to just grind off the one weld bead in the middle and pry the tube away from the frame so I can slip the bracket between the frame and the tube. That leaves just one weld bead at each end of the three feet long tubes. I may slip a hose clamp or something over it to make sure it doesn't pop off, and I may eventually just cut the wires and remove these tubes, and then solder splice the wires and use plastic corrugate or something like that.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
