alvinator
Jun 07, 2014Explorer
Off Pavement wrote:
Vacuum pump working? Does the vacuum pump run and do the brakes hold when you pull the emergency break-away switch activator?
Vacuum pump is working. I pulled the breakaway and the pedal is locked up tight. I may have the Coach dash controller improperly aligned but the coach is in the paint shop for a few days.
Al
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
