FIRE_UP
Jun 02, 2014Explorer
alvinator wrote:
Since the Ready Brake is a mechanical system, how do you get the toad turn signals to operate?
alvinator,
You've been given some info here but, not much detail. It all depends on just how much you know about and or, WANT to know about the lighting systems on various toads. You see, there are about 4-5 ways of setting up toad lights.
1. Tie into to the toads factory wiring and use the stock tail lights and bulbs, for toad lights when pulling it.
2. Drill the back side of the toads tail light housings and, install auxiliary sockets and bulbs.
3. Use magnetic lights and place them on the roof or bumper (if it will support them and, if it's metal)
4. Purchase "Plug and Play" tail light connecting systems, (if they have one for your model and year)
5. Fabricate a "light bar" that attaches to a trailer receiver on the back side of your toad, if so equipped.
Now, each one of those methods had points, good and bad. I won't go into detail on each ones issues. You can figure that out for yourself. I've used the first method for well over 25 years of towing and, it's worked on 11 different toads, without one issue ever happening. Some don't like it because it involves tying into the factory wiring and it scares many to do that. It's very simple but, again, you'll have to determine which way may work for you.
One more thing, as with ANY auxiliary braking system, i.e. Ready Brake, Even Brake, and more, the application of the toads brakes during towing, may or, may not light up the toads brake lights, even with the key in the "OFF" position. That will have to be considered when wiring your toad in the various ways. Good luck.
Scott
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
