Winged_One
Aug 11, 2013Explorer
DodgeVoltage wrote:
Did the camera just need the standard 2 wire 12 volt connection, or is it powered thru the line to the truck monitor?
2 wire 12 volt. I purchased one of these through Amazon. 12 volt plug Works fine. I plug it into the 12 volt in the back seat of the truck.
The monitor unplugs from the harness (gets its power through the harness) and I remove from the vehicle when after reaching our destination.
The camera has a wide enough angle to see much of the bike, even at close distance. A higher placement would provide all the view you could ask for.
The system allows for additional camera's to be attached.
Finally, the night vision was excellent. Just like daylight.
Looking for advice before your next adventure? Look no further.25,136 PostsLatest Activity: May 29, 2025
