Harvey51
Feb 20, 2019Explorer
On our class C I first installed a license plate mounted camera which was not very useful as depth of field was confusing. Then I got one with guidelines on the video and mounted it high up on the inside top of the rear window aimed down so the hitch is just in view. Works great. I can back up within 6 inches of a post easily. Only worry is not seeing tree branches up high - have to hop out and check for branches in person.
Whether it is a backup camera or a rear monitor is just a matter of how you hook up the power. My hookup is through a switch mounted on the base of the driver’s seat. The video cable and power was easy to install because the camera is inside. Also easy to keep clean.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
