jimbow2's avatar
jimbow2
rear-view camera
Daughter & SIL stopped by our place on there trip, they have a newer Ram & truck camper then we do... Showed me how he setup a "Camera source" rear camera fitted into the p/u screen .... Very impressed.... We have a 2016 Ram & truck camper and reviewing there site appears that perhaps they have units to fit my setup....... so right now b/4 I call "camera source" I'm just reaching out for any of you T/C'ers having experience with after market rear cameras.............. and your advice... Thank You..
  • Ordered the " camera source ' to plug in to truck and use the dash monitor of the ram..... will use the flag to see if tracker is coming along......
  • 3_tons's avatar
    3_tons
    Explorer III
    I got my Voyager thru RVcameras.com
    Oops, meant:
    https://www.rvcams.com/
    3 tons
  • Tvov's avatar
    Tvov
    Explorer II
    Have you looked into "dash cameras"? Many, if not most, you can buy with a rear view camera. Mine has a wired rear view camera designed to be mounted outside.
    Wireless ones are available.
  • jimbow2 wrote:
    good afternoon...... thanks for reply's.... Question I have regarding rear view cameras>>>. I'm looking for guidance not only backing up in reverse, BUT also as I tow my Geo-tracker or anything else to check while driving will they allow that?????? when T/C is loaded???
    If the camera i listed as rearview it is designed for full time use, back up cameras are designed for use when backing only.
    Some companies make multiple camera systems. I have a 3 camera. one on the back of the camper, one on the back of the horse trailer an one inside the horse trailer to monitor the horse in transit. Mine is by Tadibrothers
  • good afternoon...... thanks for reply's.... Question I have regarding rear view cameras>>>. I'm looking for guidance not only backing up in reverse, BUT also as I tow my Geo-tracker or anything else to check while driving will they allow that?????? when T/C is loaded???
  • I have the Camera Source camera on the Bigfoot. I bought the salt spreader version. It has all the wiring to attach right to the truck harness. GM plugs to an aircraft connector with a threaded locking system, to a 10 foot extension, to the camera,which I mounted above the door of the camper. This is on a 2014 Chevrolet Silverado with the OEM tailgate camera. They had the same thing for Ram.
    Brian
  • I liked the camera linked to my phone, put as many cameras as you like on it .
  • 3_tons's avatar
    3_tons
    Explorer III
    Interesting…When I first researched RV camera’s I discovered that not all camera’s are equal - some were true RV driving cameras, whereas some were for backing up only…Apparently, the difference is in the camera itself - a back up camera is not designed for continuous viewing due to heat buildup…
    Having said that (me having a 16, RAM..), then there’s the question of proprietary camera and wiring harness compatibility, so it would be interesting to know what make and model of camera he used…
    3 tons
