Tvov
Oct 27, 2016Explorer II
Is the hitch all the way down on the ball? Meaning, is your tongue jack retracted all the way? When in a rush I've tried to lock the hitch without having the tongue jack all the way up, basically while I'm still retracting the jack. If the jack is touching the ground (or wood spacer under it, however you do it), it may be holding up the tongue more than you think.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
