path1
Jul 12, 2016Explorer
I was getting an egg shaped receiver hole where the drift pin goes. I put on what is called "double split shaft collar" at each side. Tension or pull is now at 90 degrees to pin, not one side or the other, which I think was causing abnormal wear.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 07, 2026
