Gjac
Jul 26, 2017Explorer III
If you have 2 6v GC batteries what you suggested will work fine. That model is suppose to be an improved version of the B&D 40 amp charger. You can leave your other converter charger in place while using the portable. You won't charge your batteries completely using the generator just to about 80 percent. Check your charger output first it may be putting out 40 or 50 amps already, which will be fine for 1 12v or 2 6 v batteries. Post your model charger here and you will get more accurate advice.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 12, 2026
