alliemac9's avatar
alliemac9
Recommendations for RV Garage?
I probably can't afford a "dream" garage, but we are considering constructing a garage for storing our RV at home and want to consider what to incorporate. Currently, we are fortunate to have a heated warehouse space to store it in; however, that may change so I want to determine if a garage is a viable option.
Before I get a couple of bids, I thought I'd ask the forum experts. We currently have a pretty small Class C, and while we have no plans for something larger, I want to consider building something long/high enough to accommodate most RV's for future property value reasons. So, here goes:
1. Garage size? Interior length, width and height?
--Based on where this would sit, we would have a single-wide garage.
2. Door height?
--Is 10'Wx12'H enough? or should I go 12x14?
3. Slab thickness?
--I assume this will be determined by design/code, but thought I'd see if anyone had input.
4. Heating method?
--We are in the Denver area and are currently spoiled because we don't have to winterize. We can winterize, that's not a big deal, but we will likely put a heat source in the garage one way or another. We plan to insulate well (2x6 construction). So, just a gas furnace like our house garage? Anyone done radiant in-floor heat? Is that more or less economical if you were trying to maintain 40 degrees in the winter? Could that be bad for some other reason?
5. Ventilation?
--Not certain what the options are here, but I wouldn't mind being able to ventilate when needed without opening the doors - some sort of forced air system. Haven't put much thought into this yet, so it's kind of a random issue.
6. Anything else you didn't consider and wish you had???
Thanks!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
