fla-gypsy
Apr 18, 2014Explorer
Jayco23FB wrote:Drbolasky wrote:
I've been towing our rig with the DC setup for 12 years. It is more than adequate.
Set up is straight-forward but DO follow the instructions to the letter. I found it helpful to take the rig for some test-drives experimenting with differing numbers of links under tension/ball mount angle, etc.
I just installed a Reese DC but havn't had a chance to tow with it any distance as yet. What are you looking for when differing the number of links? Thanks
How much weight is distributed is partly controlled by the number of links under tension on the DC. BTW, more is not always better. It is the balance of weight distributed to the truck axles that is key.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
