goducks10
Apr 18, 2014Explorer
IMO a PP or HA are only needed when you can't dial in any other WDH. Or you like having the best WDH even though it's not needed. You have a 3/4 ton truck weighing 7000-8000lbs towing a TT with a GVW of around 7000lbs.
Properly set up you should have zero sway. If you can find a used HA for $600.00 and it has the right stinger then I'd get one. But no way would I spend $2500.00 if I didn't have to. The Reese or even an EQ (which is way easier to setup) would work fine.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
