JBarca
Apr 18, 2014Nomad II
backlater wrote:
We are new at this and we just purchased an Airstream 25 foot travel trailer and a 2015 Chevrolet Silverado 2500. We are wondering which hitch would be better a Reese Dual Cam or a Pro-Pride. Is the Reese Dual Cam enough or are we still going to get sway? My husband thinks the Dual Cam will be sufficient, but I am a scardy cat and I don't want any sway. I would appreciate any input from the experienced pros out there...thanks! - Ruth
Hi Ruth,
To your first question, which is better? For trailer sway mitigation, the mechanical concept of the Pro pride or Hensley hitch when working correctly, will out perform the DC. This is an uncontested fact by the way the 2 hitches work.
To the 2nd question, is the DC enough? The DC is a good piece of towing equipment and when setup correctly, on a properly balanced camper with the proper size truck and tires on the truck, it is a very good system.
Your 2500HD is a very good truck, your Airsteam is a good towing camper from it's aerodynamics. If the camper is balanced correctly and the tires on the truck are aired up correctly for towing, from my towing experience the DC will do a good job your you. It will take a level of understanding on any anti sway hitch to set it up correct and the DC needs to be set up correctly or it can give you problems same as the Propride.
Towing a camper is a serious thing, a lot can go wrong and should be taken serious. However through towing education, learning, proper towing setup, it can be a enjoyable and safe experience.
I have several friends who have the Hensley system and it is not because they had to have it, but because they wanted it. Even to the experienced tower, the premium hitches offer advantages.
If you start with the DC,and educate yourself on it, it will do good for you. If you find you want to take towing to the next level of risk mitigation, you can sell the Reese system on Craig's list and upgrade to the Pro Pride. I will say to shy away from the Reese round bar system with the DC and to get the Reese Trunnion bar system with the DC. The Reese round bar hitch head does have some shortcomings when the DC is added. The trunion bar system offers more advantages.
Hope this helps and good luck with your new camper.
John
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
