gpeade's avatar
gpeade
Reese Dual cam vs Equalizer
First off I am not trying to beat a dead horse here to decide which is the better hitch. I have not owned a TT for more than 10yrs but thinking about getting another one. Probably been that long since I have been here as well.
Previously I had a Reese dual cam and loved it. Easy to hitch and unhitch and never had any sway issues.(not that the hitch was entirely responsible for that)I say I loved it but I had nothing else to compare it too. The Reese is the only WD hitch I have ever used.
The dealer I visited recently sold Equalizer products. Exactly where does the equalizer generate the sway control? In looking on the website it looks to me it's in the joint where the WD bar attached to the hitch itself but my salesman said it was simply friction from the metal on metal contact from the bar resting on the take up bracket. For me, I would think the dual cam on the reese would preform more effectively.
I would like to hear opinions, experiences from those of you that have possible used both.
Please skip the post telling me I NEED a Hensley. I'm aware of the product but not spending that kind of money for what I will be doing.
Thanks
  • I've used both for many years. I much prefer the Dual Cam over the friction system.
  • Your salesman was mistaken. The main sway control on the Equal-i-zer 4 point hitch comes from the friction between the two sockets where the bars insert into the hitch head and the upper metal portion of the hitch head. The amount of pressure on that surface when the bars are tensioned is tremendous. This is what they are talking about when they say "rotational sway control". They count each bars socket as one point of tension each.
    The secondary points of sway control (3-4 of the 4 point) is the contact surface of the WD bars on the flat portion of the L brackets. There is one on each side of the A frame so they are counted as one point of tension each - hence the advertising claim of 4 way sway control.
    The amount of steel on steel pressure is MUCH greater at the hitch head compared with the pressure on the L brackets so most of the sway control comes from this area.
    Hope this helps understand it a bit. :)
    Regarding the Dual Cam system - The big advantage to that one is that the tension increases the more the trailer tries to swing. Also, the Dual Cam does not restrict the trailer from returning back to center like the Equal-i-zer does. The Equal-i-zer tries to hold the trailer in position no matter what angle it is at. That means that the same amount of sway control tries to keep the trailer "turned" as it did when going straight. This is in contrast to the Dual Cam which assists the trailer in straightening up after a turn or sway event.
    One big advantage to the Equal-i-zer is it's ease of installation and adjustment. The Dual Cam can be quite difficult is some cases to get installed and adjusted. It take much more time but the effort is usually well worth the time. I towed for years with the Dual Cam system and that is what I would go with again if I were you, especially since you are familiar with the hitch.
    Barney
  • Straight from the Equalizer site...
    "The rigidity of the sway control brackets allow the rotational friction sway control to safely and effectively hold the trailer in line behind the tow vehicle and combat sway."
    That said, we've had our EQ hitch for 9 years and I have found that lubing the ball and the swing-arms of the hitch head does wonders for the noise without impacting the friction control of the system.
  • Both are good...Both need to be set up correctly and dialed in. Reece is a little more difficult initially.
    I've had both and if I had to pick, I'd go with the Reece... my wife hated the screeching and popping sounds the Equal-i-zer made. The Reece was much quieter.
    Bottom line - you can't go wrong with either...but if you are familiar with and have experience with the Dual Cam, that's what I would go with.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
