- RiceExplorer IIII have a 4-door Norcold (2 refrigerator doors and 2 freezer compartments) and measured propane use when boondocking in warm, humid weather that was temperate enough to sleep in without air conditioning. I've got statistics from several months of this.
It averages about 1/2 gallon per day.
Maybe the people citing 1/4 gallon (or one pound) per day have a smaller unit? - Dog_TrainerExplorerThanks to all of you for your replies. It looks like no trouble with the 10 days . I want to leave it on because I think it is better for the refer to run continuous rather that stop and start.
- mlts22Explorer IIAs a rule of thumb, I go by a pound a day for propane use. 28 gallons of propane will last you about 3-4 months, assuming nothing else is using gas. This is something I personally found when camping, as well as from friends who have reused cast-off absorption fridges for off-grid use.
- Ron3rdExplorer IIIDog Trainer, you'll be fine for 10 days with your setup. Fridg's sip propane.
- TothillExplorerNot sure if this will help you but we fill our propane tank at the beginning of each summer. Our hot water is propane only, so we use it there too.
We have never had to top up the propane tank over the course of a summer. Most days camping about 40 with half no hook-ups.
We do use the propane stove, to a small extent, we generally cook outside. - RJCorazzaExplorerMy previous fridge used about 0.25 gallons per day in moderate temperatures.
naturist wrote:
Variables not mentioned by the OP: size of propane tank (20 lb? 30 lb? more?), whether said tank(s) are full or partly empty, size of refer, outside temperatures, inside RV temperatures. All have a large effect on the propane consumption rate, making any sort of useful answer difficult.
As someone mentioned, 12v electric is also crucial to the operation of that refer, so is the rig on shore power or battery only? and if the latter, is anything else on, how many batteries does he have, and what is their state of charge?
The REAL question of whether he can leave that rig/refer on for 10 days depends on the answers to all those OTHER questions.
What do all those variables have to do with propane consumption that is the question I asked. I have 6 house batteries all at full charge and 28 gallons of propane near full. Now can we get back to the question of consumption. And BTW what are the other questions ? - naturistNomad IIVariables not mentioned by the OP: size of propane tank (20 lb? 30 lb? more?), whether said tank(s) are full or partly empty, size of refer, outside temperatures, inside RV temperatures. All have a large effect on the propane consumption rate, making any sort of useful answer difficult.
The REAL question of whether he can leave that rig/refer on for 10 days depends on the answers to all those OTHER questions. - wanderingbobExplorer IIA twenty lb tank will run my fridg for 24 days before switching over .
- bobsallyhExplorer III don't know what the time length would be but we run two refers in our fiver off two 30 lb tanks with an automatic change over. At times depending on temperatures, one of the 30's may be empty. You do know that it takes 12 volt to keep that refer running even though it is on propane. So something will have to keep the batteries charged up.
