garmp's avatar
garmp
Explorer II
Aug 13, 2020
refrigerator door prop
Our new RV is great, but one draw back the fridge/freezer door has no catch to hold the door slightly ajar during storage. Any ideas on what to use. Can't use the magnet type, all plastic. Our storage parking spot is on a slight cant and the door swings open is not secured. Tried to contact Norcold, but no reply, to see if they could suggest something. It will be a while before we put it in storage, but don't want to wait till the last minute.
Thoughts, remedies, ideas, links, any help is appreciated.
thanks
  • Wow, the OP must think there is a reading comprehension problem on the forum. LOL
    He wants to keep the door ajar, i.e. slightly open, but it's parked on an angle and the door comes completely open. So far only one person has offered a possible solution: bungee cord. My vote is to put a chair or stool in front of the door to stop it from coming fully open. A towel put between the doors will keep the freezer door even with the fridge door.
    And the OP hasn't returned to answer our question about why they can't be fully open.
  • fj12ryder wrote:
    place a dish towel between the door and body of the fridge. How will that keep the door from being open completely? I'm not sure I'm visualizing that correctly.
    We place the towel over the top of the door and close it until snug.
  • I've got the little plastic things to hold mine ajar.
    As to leaving them fully open, at least in my trailer if the fridge door is open and then I put the slide out, I can have the door jammed against the slide. Did it once and it was a PITA to get it unjammed. Had to force the doors off. So now I make sure that blind is raised up to I can check the fridge doors before putting the slide out.
  • I would be opposed to leave the doors wide open as I read on another forum that someone did that for 3 months over the winter and the doors sagged and would not close tightly. Therefore I don't want even want to attempt it. Don't know the type of RV, fridge model or anything, just that it scared me as not to try this.
    Might try the newspaper or charcoal ideas if my newest brainstorm turns out to be a brain fart.
    Thanks for all the input.
  • Gjac's avatar
    Gjac
    Explorer III
    I made a plastic piece that is inserted between freezer and refer door with Velcro on end that holds both door open 1 inch and prevents doors from opening wider.
  • My Norcold has a little sliding tab just under the handle on the refrigerator and freezer. I wonder if yours does too. It looks like a pin or button just under the handle that slides out and engages a hole in the door frame. Once slid over the door will stay ajar and not open or close until you slide the tab back.
    No got. Our previous RV was set up that way also, but not this one.
    Found a tiny strip of metal around both the freezer and the fridge itself. Got some rare earth magnets, 1/4" dia, and some masonite scrapes for both the inside and outside of the doors,and fashioned a prop that should work. No holes, no marks and easily removable and replaceable.
    Thanks for all the ideas.
  • midnightsadie wrote:
    we throw a towel in each door.
    This ^
    We loop a dish towel over the bottom rack on the freezer door, plenty long enough to keep top & bottom doors open a bit.
