handsome51
Nov 17, 2014Explorer
DentRover wrote:
Do any of you have suggestions on how to keep my Norcold N81 refrigerator working when the temp goes below freezing? This is our first cold weather camping experience and we discovered the freezer has thawed.
If you run it on gas it will work fine. The flame puts just enough heat out so it will work. I found that out at 15degrees one year. When I got home I mounted permently a single light fixture with a 60watt light bulb inside the bottom vent cover. When it gets to cold I just plug the light in . It puts out enough heat so the ice box 110ac heating element works fine.
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 19, 2026
