Golden_HVAC
Feb 14, 2015Explorer
Hi,
The E-450 of that model year is Ford factory rated at about 22,000 pounds, and the transmission is strong enough at that weight The same transmission was rated at 30,000 GCVWR in the F-550 with a more powerful diesel engine.
The frame is good for the weight that you want to tow. How long is the frame extension? Normally a 20' RV will not have a frame extension at all. If the hitch is attached to the Ford factory frame, and not a extension, then Ford rates the towing ability around 10,000 pounds!
Good luck,
Fred.
Good luck,
Fred.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
