AndyW
Feb 16, 2015Explorer
Right, but what I was working around, and what it appears the OP is trying to solve, is the motorhome manufacturer (not Ford) putting a 3500lb hitch on an e450 and then only rating it to tow 3500lbs.
The chassis is rated much higher than that by Ford. The only problem is that the RV manufacturer's work, specifically the frame extensions and hitch, are only designed for 3500lbs. So get that beefed up by someone who knows what they are doing, and you're all set to tow up to the chassis limits.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
