- ktmrfsExplorer III
EsoxLucius wrote:
Stand alone meters:
TriMetric TM-2025
Victron BMV 600
Xantrex LinkPro
If you employ a Blue Sky solar charge controller, the IPN-ProRemote with the shunt kit is a good battery meter.
If you employ a Magnum inverter/charger and the ME-RC50 remote, the ME-BMK battery monitor works well.
x2. I have the trimetric 2025 in both of my trailers, works fine for me. that said the others are very good choices as well. take a look at the specs and see what fits your fancy. - EsoxLuciusExplorerStand alone meters:
TriMetric TM-2025
Victron BMV 600
Xantrex LinkPro or LinkLite
If you employ a Magnum inverter/charger and the ME-RC50 remote, the ME-BMK battery monitor works well. - Shadow_CatcherExplorerWe have the Victron http://www.victronenergy.com/battery-monitors
I needed the smaller size and prefer the easy setup and reading. It is normally set to % state of charge. - SteveAEExplorer
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 06, 2026
