mowermech
Jan 12, 2018Explorer II
Check the laws. In many states the towed vehicle must not exceed 40% of the towing vehicle's GVW. Note that usually that is a TOWING law, not a TRAILER law.
IMO, what you propose is unsafe; Towing an 8500 lb. vehicle with a 7100 lb. vehicle is a recipe for disaster, regardless of the towing capacity of the 7100 lb. vehicle. My advice: DON'T DO IT!
A trailer obviously just makes the loading worse. I don't see that as a viable option, either.
Yes, if the vehicle to be towed is not four wheel drive, with a Neutral position on the transfer case shift, the driveshaft must be removed to avoid transmission damage due to lack of lubrication.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
