- Grit_dogNavigator IIIOr peel with a razor blade. I’d try that on smooth surfaces.
- 12th_Man_FanExplorerOn hard surfaces I use plastic putty knives.You can use them on rubber roofs also if you are careful.
- Gary45Explorer1/2 inch wood chisel works well
- BrownleafExplorerMy roof is fibergl but most dicor seems to be intact. I am working on the side now. While I like the oscl tool I would be nervous about using it on the caulk removal. I will keep it in mind though. Doug
- WNYBobExplorerI replaced my skylight and of course it had lots of Dicor sealant. I removed the sealant with a blade on my oscillating tool. Now my roof is fiberglas, if you material is "rubber" roofing you may damage with this tool.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 16, 2026
