JRscooby wrote:
Lynnmor wrote:
Since he apparently destroyed the knurling in the shackles with the impact wrench, my thought is that using power tools is not the smarter thing to do. A little hard work builds character.
Did the power tool destroy, or the fact he turned the bolt?
IMHO, it was his lack of understanding of how nut/bolt should be works. To loosen or tighten the fastener, turn the nut. To get it off on, does not matter as much.
With an impact wrench it is not possible to determine how much torque you are applying so that you can oppose that torque with the wrench on the other end. I believe that he did in fact use the impact on the wrong end but hand tools are the better option IMO.
