monkey44's avatar
monkey44
Nomad II
Mar 05, 2014
removing tailgate - 2015 GM trucks w/BU-Camera
What a hassle - removing the tailgate means removing the plug to the BU camera - which is under the bed and beside the frame in a three plug connector which you have to "guess which one" first ... and then become a contortionist to reach and pull it. And, you need to be strong enough to do fingertip-pushups as well, because I could not pull it out.
And, it's almost impossible to reach without rolling under the bed... a very poor design .. each time you remove the TG, all this PITA ...
The plug requires a screwdriver to clip the pin safety off as well.
I would think if you need to remove something, it would be at least accessible. Very strange ...
  • Oh wow...had not thought about that problem. When I had a truck sans BU camera I often removed the tailgate. What a pain. Can you add/move the plug to make it easier?
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
