Winged_One's avatar
Winged_One
Removing underbelly material, what might I be getting into?
I have 3 cable pulls for my holding tanks. The toilet tank pull is harder to pull, sometimes very hard the first time used for quite a while.
Unfortunately, the valves are hidden behind the underbelly material. I want to get to them to lube them. It's the standard big black sheets that appear to be screwed in place.
Underbelly material
What kind of hell am I going to have if I try to remove and then reinstall these sheets? Will the screws hold again? Should I get new larger washers?
It looks like there is some kind of sealant along the edges. What should I use to reseal?
OR Will a commercial liquid lube you put down the toilet work just as well?
Example of lube
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
