noteven
Sep 22, 2021Explorer III
FWC wrote:
The discharge low temperature limit is typically not a hard BMS limit (like the low temperature charge limit) and there is nothing that will physically damage the cells if you discharge below -20C. It is just that the cell manufacturers don't test below -20C because few customers care about that. Some do and actually show pretty good performance down to about -45C. They will loose capacity, but not nearly as much a lead acid batteries.
Thanks FWC that's good info
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
