garyhaupt's avatar
garyhaupt
Repair completed....wrong repair.
Just driving along on Wednesday, up the Fraser Canyon and *bingo*..a weird shudder in the steering and when I stopped to check..pop pop pop out the tailpipe. A misfire. Made some calls to the shop that would normally wrench on the 1999 Ford, V10 and by my description says.."coil and or plug". "Drive it till it starts making bad sounds...don't want to melt the plug" And so, stopped between Cache Creek and Kamloops, no cel service, 3 hours for it all to get worked out and towed to Kal Tire in Kamloops, arriving as they shut down for the day. Of course.
Overnight in the yard and first thing at 7:30 at the desk..we discuss the whole thing. I related what I had been told it was..coil/plug. And they made notes, as they had done when I arrived the night before. The mechanic does his magic with the Scanner and says it's the fuel pump. Pressure is down. Drops tank, new pump arrives at 4pm, he installs..does a run-up and pronounces job well done.
I bet you know where this is going.....
I drove out...turned around the block and drove right back in. Back out comes the Scanner..hhmm...hhmm...and lo and behold, he see's it WAS a coil..on #1. It hadn't shown up on the initial scan but was shown in memory. They had ordered the parts in, in case I wanted a full tune-up..to the tune of $1,500..which I had declined, thanks very much. So..they had a coil at hand.
Then we had a chat..the counter guy and I. Ohhh...I neglected to tell you all of it...while messing around getting the coil replaced, the Asst Manager had been hanging around, trying to help..walking away with part of the air-cleaner unit. That would be the part that he then put down under a rolling door..and closed on it...the part that shows is now obsolete in Fords catalogue.
They dropped $200.00 from the $900 bill. Now they have to scrounge up the air breather part...and no, I'm not done yet.
I'm curious tho...any of you had a similar go-round? Replace part, only to find not the right one..having first told them what you wanted done.
Gary Haupt
  • Why would you take a Ford engine to a Tire shop??? Lots of Ford dealer's in Kamloops.
  • Scanner will only find electrical/electronic malfunctions not fuel pressure problems. A scanner cannot read fuel pressure. A fuel pressure gauge does that. This guy was only shotgunning parts at it. Or maybe he didn't replace anything at all. Did he give you the old part?...I would refuse to pay for the pump! If you paid by credit card dispute it. Pay for 1 hour of diagnostic, the coil and say goodbye.
    B.O.
  • Hi Gary,
    Sounds like a typical boondoggle. I'm sorry this has happened to you. $1500 seems quite a high price for a tune up. The truck dealership in Regina wants about $650.00
  • Sounds like fun Gary -- Can't advise, but I'd be thinking my truck would be running pretty good when I left there, and for not another check or CC ...
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 11, 2026
